Ir para o conteúdo principal
Connecting TI-Nspire to a Computer
O que você precisa
  1. Connecting TI-Nspire to a Computer, Connecting TI-Nspire to a Computer: passo 1, imagem 1 %32
    link to education.ti.com is no longer valid :(
    try instead:
    https://education.ti.com/en/search?q=tic...
    Bart van Dalfsen - Responder
  2. Connecting TI-Nspire to a Computer: passo 2, imagem 1 %32 Connecting TI-Nspire to a Computer: passo 2, imagem 2 %32 Connecting TI-Nspire to a Computer: passo 2, imagem 3 %32
    • Make sure you have a TI USB cable to connect your calculator and computer
    • The ends of the cable should look like those in this picture
  3. Connecting TI-Nspire to a Computer: passo 3, imagem 1 %32 Connecting TI-Nspire to a Computer: passo 3, imagem 2 %32
    • Insert the plug into the the slot at the top of the calculator.
  4. Connecting TI-Nspire to a Computer: passo 4, imagem 1 %32
    • Connect the calculator to the computer through the USB port
    • Through the TI connect program you are ready to perform actions such as viewing your calculator display on your computer screen
Linha de Chegada
19 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 7-52, Forte Fall 2012 Membro de Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
Membros da 5
Autoria de 12 guias
5 comentários
This didn't work for me. According to the ti download page for the software the NSPIRE is not listed as a supported device. It appears that the software for the NSPIRE is not free.
no way - Responder
the software link is wrong
here is the correct one
https://education.ti.com/en/software/det...
Maximman101 - Responder
the link is denied,
Fashion - Responder
The link is denied
Fashion - Responder
The link worked, and I can connect! Thanks!!
Octav Mandru - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 95
Últimos 30 dias: 304
Duração total: 94,023
