Ir para o conteúdo principal
Connect Four Electronic Handheld Battery Replacement
O que você precisa
  1. Connect Four Electronic Handheld Battery Replacement, Ensure the device is off.: passo 1, imagem 1 %32
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Battery Replacement, Removing the battery casing.: passo 2, imagem 1 %32 Connect Four Electronic Handheld Battery Replacement, Removing the battery casing.: passo 2, imagem 2 %32
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Battery Replacement, Replacing the battery.: passo 3, imagem 1 %32
    • Put in the new AA battery, ensuring that the negative end slides into the spring.
Conclusão
Kamaryn
Membro desde: 10/22/14
225 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 8-11, Williams Fall 2014 Membro de Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 211
