Ir para o conteúdo principal
Connect Four Electronic Handheld Back Casing Replacement
O que você precisa
  1. Connect Four Electronic Handheld Back Casing Replacement, Ensure the device is off.: passo 1, imagem 1 %32
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: passo 2, imagem 1 %32 Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: passo 2, imagem 2 %32
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: passo 3, imagem 1 %32 Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: passo 3, imagem 2 %32
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
Conclusão
Wil
Membro desde: 10/22/14
313 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 8-11, Williams Fall 2014 Membro de Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 104
