Ir para o conteúdo principal
Conair True Glow Lighted Mirror LED Bulb Replacement
O que você precisa
  1. Conair True Glow Lighted Mirror LED Bulb Replacement, LED Bulb: passo 1, imagem 1 %32
    • Unplug and remove batteries to make sure the ring light does not turn on while repairing.
  2. Conair True Glow Lighted Mirror LED Bulb Replacement: passo 2, imagem 1 %32 Conair True Glow Lighted Mirror LED Bulb Replacement: passo 2, imagem 2 %32 Conair True Glow Lighted Mirror LED Bulb Replacement: passo 2, imagem 3 %32
    • Remove the two 2 mm screws on the side of the ring mirror (one on each side) using a Phillips #00 screwdriver.
  3. Conair True Glow Lighted Mirror LED Bulb Replacement: passo 3, imagem 1 %32
    • Push the cover towards you and slide away from the rest of the mirror.
  4. Conair True Glow Lighted Mirror LED Bulb Replacement: passo 4, imagem 1 %32
    • Using your hands, gently unscrew the old LED light bulb in a counter-clockwise direction.
  5. Conair True Glow Lighted Mirror LED Bulb Replacement: passo 5, imagem 1 %32
    • Use your hands to screw in the new LED light bulb in a clockwise direction.
  6. Conair True Glow Lighted Mirror LED Bulb Replacement: passo 6, imagem 1 %32
    • Take the cover and push it back down in place.
  7. Conair True Glow Lighted Mirror LED Bulb Replacement: passo 7, imagem 1 %32
    • Screw in the two 2 mm screws on each side of the mirror using a Phillips #00 screwdriver.
  8. Conair True Glow Lighted Mirror LED Bulb Replacement: passo 8, imagem 1 %32
    • Plug the mirror in and reinsert batteries to turn it on.
  9. Conair True Glow Lighted Mirror LED Bulb Replacement: passo 9, imagem 1 %32
    • Enjoy your fixed LED ring mirror light!
Linha de Chegada
Uma outra pessoa concluiu este guia.
Dave Inthavong
Membro desde: 01/19/21
216 Reputação
Autoria de 1 guia
Um comentário
What to do to get over to release. I’ve taken the screws out but cannot get the cover to release.
Bonnie Smith - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 58
Duração total: 2,614
