Introdução
If your hair dryer's nozzle is overheating, this guide will show you how to replace the heat shield.
O que você precisa
Hold the hair dryer by the nozzle so that the handle points to the left.
Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
Hold the heating element with the wider end facing upward.
Gently pull the heating element out of the heat shield.
