Ir para o conteúdo principal
Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement
O que você precisa
    1. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Back Panel: passo 1, imagem 1 %32
      • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
      • Hold the hair dryer by the handle so that the back panel faces up.
      Pergunte ao FixBot
      Comentar
    2. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: passo 2, imagem 1 %32 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: passo 2, imagem 2 %32
      • Remove the two 15.875 mm Phillips #2 screws from the back panel.
      Pergunte ao FixBot
      Comentar
    3. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: passo 3, imagem 1 %32 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: passo 3, imagem 2 %32 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: passo 3, imagem 3 %32
      • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
      • Continue separating the back panel, working along the seam.
      • With moderate force, completely remove the back panel from the hair dryer.
      Pergunte ao FixBot
      Comentar
    1. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: passo 4, imagem 1 %32 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: passo 4, imagem 2 %32
      • Hold the hair dryer by the nozzle so that the handle points to the left.
      • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
      Pergunte ao FixBot
      Comentar
    2. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: passo 5, imagem 1 %32 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: passo 5, imagem 2 %32 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: passo 5, imagem 3 %32
      • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
      • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
      • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Timothy Lo
Membro desde: 04/22/14
1.214 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 10-58, Amido Spring 2014 Membro de Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 49
Ao todo: 8,592
