Ir para o conteúdo principal
Conair Infiniti PRO Spin Air Brush Circuit Board Replacement
O que você precisa
  1. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32
    • Look for the black screw covers near the top of the brush. Take the covers off with flat head screw driver.
    Pergunte ao FixBot
    Comentar
  2. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the screws that secure the brush head.
    Pergunte ao FixBot
    Comentar
  3. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 3, imagem 1 %32
    • Gently take off the brush top.
    Pergunte ao FixBot
    Comentar
  4. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 4, imagem 1 %32
    • Take out the black gear by pulling up.
    Pergunte ao FixBot
    Comentar
  5. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 5, imagem 1 %32
    • Take the top of air filter off.
    Pergunte ao FixBot
    Comentar
  6. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 6, imagem 1 %32
    • Use flat head screwdriver to pop off the bottom air filter.
    Pergunte ao FixBot
    Comentar
  7. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 7, imagem 1 %32
    • Gently use a flat head screw driver to take of the black cover, covering the plastic shell.
    Pergunte ao FixBot
    Comentar
  8. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 8, imagem 1 %32
    • Using your flat head screwdriver to go along the seams of the plastic shell till the shell pops apart.
    Pergunte ao FixBot
    Comentar
  9. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 9, imagem 1 %32
    • Then take the switch cover and buttons off.
    Pergunte ao FixBot
    Comentar
  10. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 10, imagem 1 %32
    • Then take your Philips screw driver (ph1 size head) and unscrew the circuit board. The screw is located in the middle of the board.
    Pergunte ao FixBot
    Comentar
  11. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: passo 11, imagem 1 %32
    • Remove the black heater cover by sliding it off.
    • Desolder each of the four connections, and remove the circuit board.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
andrew shirley
Membro desde: 08/23/17
393 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G3, Freund Fall 2017 Membro de IUPUI, Team S1-G3, Freund Fall 2017
IUPUI-FREUND-F17S1G3
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 44
Ao todo: 1,704
