Ir para o conteúdo principal
Conair Infiniti PRO Curling Iron Motherboard Replacement
O que você precisa
  1. Conair Infiniti PRO Curling Iron Motherboard Replacement, Housing: passo 1, imagem 1 %32
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Motherboard Replacement: passo 3, imagem 1 %32 Conair Infiniti PRO Curling Iron Motherboard Replacement: passo 3, imagem 2 %32 Conair Infiniti PRO Curling Iron Motherboard Replacement: passo 3, imagem 3 %32
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Motherboard Replacement, Power Cord: passo 4, imagem 1 %32
    • Pull power chord out.
  5. Conair Infiniti PRO Curling Iron Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
    • Note the location of wire attachment.
  6. Conair Infiniti PRO Curling Iron Motherboard Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
    • With your soldering gun, desolder the white wire from the motherboard as shown.
  7. Conair Infiniti PRO Curling Iron Motherboard Replacement: passo 7, imagem 1 %32
    • Once both wires are desoldered the motherboard can be removed.
Conclusão
To reassemble your device, follow these instructions in reverse order, making sure to resolder the wires correctly into the replacement motherboard.
Jonathon Bruer
Membro desde: 11/09/17
607 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S7-G5, Baechle Fall 2017 Membro de IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 572
