Introdução
This guide will build off of the Housing and Power Cord Removal guides to remove and replace the motherboard.
O que você precisa
Heat up your soldering gun and desolder the red wire from the motherboard as shown.
Ferramenta utilizada nesse passo:Desoldering Pump$3.99
With your soldering gun, desolder the white wire from the motherboard as shown.
To reassemble your device, follow these instructions in reverse order, making sure to resolder the wires correctly into the replacement motherboard.
