Ir para o conteúdo principal
Conair Infiniti PRO Curling Iron Heating Element Replacement
O que você precisa
  1. Conair Infiniti PRO Curling Iron Heating Element Replacement, Housing: passo 1, imagem 1 %32
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 2, imagem 1 %32
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 3, imagem 1 %32 Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 3, imagem 2 %32 Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 3, imagem 3 %32
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Heating Element Replacement, Power Cord: passo 4, imagem 1 %32
    • Pull power chord out.
  5. Conair Infiniti PRO Curling Iron Heating Element Replacement, Motherboard: passo 5, imagem 1 %32
    • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
    • Note the location of wire attachment.
  6. Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
    • With your soldering gun, desolder the white wire from the motherboard as shown.
  7. Conair Infiniti PRO Curling Iron Heating Element Replacement: passo 7, imagem 1 %32
    • Once both wires are desoldered the motherboard can be removed.
  8. Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: passo 8, imagem 1 %32 Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: passo 8, imagem 2 %32
    • Remove the heating element mount. This will free up the heating element barrel for replacement.
Conclusão
3 outras pessoas executaram este guia.
Jonathon Bruer
Membro desde: 11/09/17
607 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S7-G5, Baechle Fall 2017 Membro de IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 1,506
