Ir para o conteúdo principal
Conair Cord-Keeper 169XR Cool Down Button Replacement
O que você precisa
  1. Conair Cord-Keeper 169XR Cool Down Button Replacement, Handle Cover: passo 1, imagem 1 %32 Conair Cord-Keeper 169XR Cool Down Button Replacement, Handle Cover: passo 1, imagem 2 %32
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR Cool Down Button Replacement: passo 2, imagem 1 %32
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR Cool Down Button Replacement, Cool Down Button: passo 3, imagem 1 %32 Conair Cord-Keeper 169XR Cool Down Button Replacement, Cool Down Button: passo 3, imagem 2 %32
    • Take out the cool down button and the spring behind it by gently lifting the button up toward you and pushing it to the right out of its groove.
    • You may need to replace the button and spring depending on which one is broken.
Conclusão
Uma outra pessoa concluiu este guia.
Candace
Membro desde: 01/23/14
1.010 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 10-33, Maness Winter 2014 Membro de Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
3 Membros
Autoria de 14 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 1,324
