Ir para o conteúdo principal
Computer King Muffin Kinder 7 Screen Replacement
O que você precisa
  1. Computer King Muffin Kinder 7 Screen Replacement, Screen: passo 1, imagem 1 %32 Computer King Muffin Kinder 7 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Screen Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Screen Replacement: passo 3, imagem 1 %32 Computer King Muffin Kinder 7 Screen Replacement: passo 3, imagem 2 %32
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Screen Replacement: passo 4, imagem 1 %32
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Screen Replacement: passo 5, imagem 1 %32 Computer King Muffin Kinder 7 Screen Replacement: passo 5, imagem 2 %32
    • There will be a black strip connected to the screen.
    • Use the pointy end of the spudger to unstick the black strip that is glued onto the screen.
  6. Computer King Muffin Kinder 7 Screen Replacement: passo 6, imagem 1 %32 Computer King Muffin Kinder 7 Screen Replacement: passo 6, imagem 2 %32 Computer King Muffin Kinder 7 Screen Replacement: passo 6, imagem 3 %32
    • You will need to remove 2 ribbon cables, one that is connected to the touch screen (by the battery) and one that is connected to the yellow plastic (by the speaker).
    • Use the flat end of the spudger to lift the black panel covering the ribbon cables.
  7. Computer King Muffin Kinder 7 Screen Replacement: passo 7, imagem 1 %32
    • Pull the two ribbon cables out so that they are no longer connected to the logic board.
  8. Computer King Muffin Kinder 7 Screen Replacement: passo 8, imagem 1 %32
    • Lift up the logic board and black plastic so that they are no longer covering the screen
    • Lift out the screen.
Conclusão
3 outras pessoas executaram este guia.
Katherine
Membro desde: 01/22/15
439 Reputação
Autoria de 3 guias
Equipe
UWT Liner: Group 2 Membro de UWT Liner: Group 2
Community
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 538
