Ir para o conteúdo principal
Compaq iPAQ Pocket PC 3830 Battery Replacement
O que você precisa
  1. Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: passo 1, imagem 1 %32 Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: passo 1, imagem 2 %32
    • Remove the four 0.8 mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Battery Replacement: passo 2, imagem 1 %32
    • Detach the yellow wire from comb that is attached to the battery.
  3. Compaq iPAQ Pocket PC 3830 Battery Replacement: passo 3, imagem 1 %32
    • The yellow wire is removed from the comb attached to the battery.
  4. Compaq iPAQ Pocket PC 3830 Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery using tweezers from back cover.
  5. Compaq iPAQ Pocket PC 3830 Battery Replacement: passo 5, imagem 1 %32
    • Detach the battery from back cover.
Conclusão
3 outras pessoas executaram este guia.
Sedina Cavcic
Membro desde: 09/05/14
464 Reputação
Autoria de 3 guias
Equipe
2 comentários
One question; Where can I get a new battery????
Every place I have looked have a smaller batter,  not like the one you show.
Stephen
oharasc85@gmail.com
Stephen O'Hara - Responder
we are in need of battery
Danionics DLP 305590
Quantity : 02 Nos.
Please send us the lowest estimate.
Mail ID: electronics@pmtpims.org
ELECTRONICS1 PIMS - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Duração total: 3,132
