Ir para o conteúdo principal
Compaq Presario v2000 mother board Replacement
O que você precisa
  1. Compaq Presario v2000 mother board Replacement, mother board: passo 1, imagem 1 %32
    • Start by removing the battery
  2. Compaq Presario v2000 mother board Replacement: passo 2, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 2, imagem 2 %32
    • Loosen the two screws of the hard drive cover
    • The screws will remain in the cover
    • Remove the cover, then pull straight up on the pull tab to remove the hard drive
  3. Compaq Presario v2000 mother board Replacement: passo 3, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 3, imagem 2 %32
    • Loosen the two screws on the ram cover and remove
    • Loosen the one screw on the wireless card cover and remove
    • These screws will remain in their covers
  4. Compaq Presario v2000 mother board Replacement: passo 4, imagem 1 %32
    • Remove 16 bottom cover screws (dark coloured 6mm screws)
    • Remove 5 screws from inside the battery bay (silver coloured 4mm screws)
  5. Compaq Presario v2000 mother board Replacement: passo 5, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 5, imagem 2 %32 Compaq Presario v2000 mother board Replacement: passo 5, imagem 3 %32
    • Using a small flat blade screwdriver pop off the wireless aerial connectors from the wireless card
    • The wireless connecters are easily damaged. Lift the connecters straight up. When reassembling line them up carefully and push them straight down
    • Unroute the cables from the bottom of the case
    • Slide out the dvd drive
  6. Compaq Presario v2000 mother board Replacement: passo 6, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 6, imagem 2 %32 Compaq Presario v2000 mother board Replacement: passo 6, imagem 3 %32
    • Flip the laptop over and open the display to start removing the keyboard
    • Slide a small flat blade screwdriver between the insert and delete keys and lever the button board cover off
    • Remove the four keyboard screws (dark coloured 4mm screws)
    • Lift up the keyboard, but beware of the cable underneath still to be removed
    • Loosen the socket for the keyboard cable and remove the keyboard
  7. Compaq Presario v2000 mother board Replacement: passo 7, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 7, imagem 2 %32 Compaq Presario v2000 mother board Replacement: passo 7, imagem 3 %32
    • Remove the display cable connector by lifting it straight up
    • Un-route the wireless aerial cables from the top cover
    • Remove the four display screws (dark coloured 5mm screws). Lift the display up and off
  8. Compaq Presario v2000 mother board Replacement: passo 8, imagem 1 %32
    • Use a flat blade screwdriver to loosen the touchpad cable connecter
  9. Compaq Presario v2000 mother board Replacement: passo 9, imagem 1 %32
    • Flip the laptop over and grip the bottom case where the dvd drive used to be
    • Lift off the bottom case
  10. Compaq Presario v2000 mother board Replacement: passo 10, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 10, imagem 2 %32
    • Remove two screws from the s-video/usb board (silver coloured 4mm screws)
    • Lift the board from the right hand side
    • The connecter for this board is under the right hand side. When reassembling, make sure this connecter plugs in firmly
  11. Compaq Presario v2000 mother board Replacement: passo 11, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 11, imagem 2 %32 Compaq Presario v2000 mother board Replacement: passo 11, imagem 3 %32
    • Remove the speaker cable and lift out the speaker module
    • Use a flat blade screw driver to loosen the button board connecter
    • Push the two wireless card arms outwards to remove the wireless card
  12. Compaq Presario v2000 mother board Replacement: passo 12, imagem 1 %32
    • Remove the four screws holding the mother board in place (silver coloured 4mm screws)
    • The screw holes are marked "PA/PR" or "PR". When reassembling do not put a screw in the hole marked "PA"
  13. Compaq Presario v2000 mother board Replacement: passo 13, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 13, imagem 2 %32 Compaq Presario v2000 mother board Replacement: passo 13, imagem 3 %32
    • Remove the left side of the motherboard first. It may be necessary to bent the case a little to get the firewire and USB port away from the case
    • Pull on the middle of the board next, angling up to clear the front audio jacks from the case
    • Pull the board away from the right side of the case
  14. Compaq Presario v2000 mother board Replacement: passo 14, imagem 1 %32 Compaq Presario v2000 mother board Replacement: passo 14, imagem 2 %32
    • Remove the three screws holding the heatsink to the mother board (silver coloured 4mm screws)
    • Remove the heatsink fan connecter
    • Lift the heatsink off the board
    • Use a flat blade screwdriver to turn the CPU lock and remove the CPU
Conclusão
To reassemble your device, follow these instructions in reverse order. See special reassembly notes in steps 10 and 12.
7 outras pessoas executaram este guia.
Andrew
Membro desde: 05/08/10
1.341 Reputação
Autoria de 5 guias
Um comentário
How to clean the fan cooler? do i have to disassemble it whole or can i just blow it from the outside, no tools?
Marcos Mora - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 42
Duração total: 5,804
