Ir para o conteúdo principal
Compaq Presario V2414NR WiFi Card Replacement
O que você precisa
  1. Compaq Presario V2414NR WiFi Card Replacement, Battery: passo 1, imagem 1 %32
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR WiFi Card Replacement: passo 2, imagem 1 %32 Compaq Presario V2414NR WiFi Card Replacement: passo 2, imagem 2 %32
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR WiFi Card Replacement, RAM Cover: passo 3, imagem 1 %32 Compaq Presario V2414NR WiFi Card Replacement, RAM Cover: passo 3, imagem 2 %32
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR WiFi Card Replacement, WiFi Card: passo 4, imagem 1 %32 Compaq Presario V2414NR WiFi Card Replacement, WiFi Card: passo 4, imagem 2 %32
    • Loosen the 5mm Phillips #1 screw that secures the Mini PCI compartment cover to the computer.
    • This screw is captured to the cover panel.
    • Lift the rear edge of the Mini PCI compartment cover, and swing it forward to remove it.
  5. Compaq Presario V2414NR WiFi Card Replacement: passo 5, imagem 1 %32 Compaq Presario V2414NR WiFi Card Replacement: passo 5, imagem 2 %32
    • Make note of which cable is attached to which clip on the WiFi card before disconnecting the cables.
    • Disconnect the wireless antenna cables from the WiFi card by prying gently upwards on the metal part of the connector with a spudger or plastic opening tool.
  6. Compaq Presario V2414NR WiFi Card Replacement: passo 6, imagem 1 %32 Compaq Presario V2414NR WiFi Card Replacement: passo 6, imagem 2 %32
    • Use your fingernails, or plastic opening tools, to spread the metal retaining tabs on each side of the WiFi card outwards until the card pops up.
    • Pull the WiFi card out of the socket at the same angle it is now oriented.
    • When reassembling, align the offset notch on the WiFi card contacts with the tab on the socket and insert at a 30 degree angle.
Conclusão
Rylie Schmidt
Membro desde: 04/19/15
765 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 476
