Ir para o conteúdo principal
Compaq Presario V2414NR Keyboard Replacement
O que você precisa
  1. Compaq Presario V2414NR Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR Keyboard Replacement: passo 2, imagem 1 %32 Compaq Presario V2414NR Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR Keyboard Replacement, Optical Drive: passo 3, imagem 1 %32 Compaq Presario V2414NR Keyboard Replacement, Optical Drive: passo 3, imagem 2 %32
    • On the optical drive there is small pin hole. Insert a paperclip or similarly sized object in the hole.
    • The Drive will pop a short way out of the computer.
  4. Compaq Presario V2414NR Keyboard Replacement: passo 4, imagem 1 %32 Compaq Presario V2414NR Keyboard Replacement: passo 4, imagem 2 %32 Compaq Presario V2414NR Keyboard Replacement: passo 4, imagem 3 %32
    • Remove the 7mm Phillips #1 screw that secures the optical drive to the computer.
    • Grip the sides of the Optical Drive and slide it out until it is completely removed from the computer.
    • When reassembling, slide the optical drive straight in until it clicks.
  5. Compaq Presario V2414NR Keyboard Replacement, Keyboard: passo 5, imagem 1 %32
    • Remove the two 4mm Philips #1 screws that secure the switch cover to the computer.
    • Turn the computer display-side up with the front panel toward you.
    • Open the computer display as far as possible.
  6. Compaq Presario V2414NR Keyboard Replacement: passo 6, imagem 1 %32
    • Insert a plastic opening tool into the slots located behind the [F5] key and lift the front edge of the switch cover until it disengages from the computer.
    • Insert a plastic opening tool into the slots located behind the [Insert] key and lift the front edge of the switch cover until it disengages from the computer.
    • Remove the switch cover.
  7. Compaq Presario V2414NR Keyboard Replacement: passo 7, imagem 1 %32 Compaq Presario V2414NR Keyboard Replacement: passo 7, imagem 2 %32 Compaq Presario V2414NR Keyboard Replacement: passo 7, imagem 3 %32
    • Remove the four 3mm Phillips #1 screws that secure the keyboard to the computer.
    • Swing the rear edge of the keyboard up and forward until it rests on the palm rest.
  8. Compaq Presario V2414NR Keyboard Replacement: passo 8, imagem 1 %32
    • Use your fingernails or two plastic opening tools to push the white portion of the ZIF connector towards the hinge of the computer.
    • Remove the ribbon cable from the ZIF connector.
    • Remove the keyboard.
Conclusão
Rylie Schmidt
Membro desde: 04/19/15
765 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 298
