Ir para o conteúdo principal
Compaq Presario CQ62-215dx CPU Replacement
O que você precisa
  1. Compaq Presario CQ62-215dx CPU Replacement, CPU: passo 1, imagem 1 %32
    • Turn the laptop upside down.
    • Remove all the 3.0mm Phillips #00 screws from the back cover.
  2. Compaq Presario CQ62-215dx CPU Replacement: passo 2, imagem 1 %32
    • Remove the battery, RAM, and hard drive.
  3. Compaq Presario CQ62-215dx CPU Replacement: passo 3, imagem 1 %32
    • Remove four 1.2mm Phillips #00 screws under the battery.
  4. Compaq Presario CQ62-215dx CPU Replacement: passo 4, imagem 1 %32
    • Turn the laptop over, and open the laptop cover.
    • Use a spudger or your hand to carefully remove the keyboard.
  5. Compaq Presario CQ62-215dx CPU Replacement: passo 5, imagem 1 %32
    • Use a spudger or your hand to lift the outside frame from the corner of the laptop.
  6. Compaq Presario CQ62-215dx CPU Replacement: passo 6, imagem 1 %32
    • Remove all the 1.2mm Phillips #00 screws from the motherboard and in the top corner that secures the fan.
  7. Compaq Presario CQ62-215dx CPU Replacement: passo 7, imagem 1 %32
    • Unplug the wires connected to the motherboard with a spudger.
  8. Compaq Presario CQ62-215dx CPU Replacement: passo 8, imagem 1 %32
    • Remove the two 3mm Phillips #00 screws beside the fan.
  9. Compaq Presario CQ62-215dx CPU Replacement: passo 9, imagem 1 %32
    • Lift the motherboard out carefully.
  10. Compaq Presario CQ62-215dx CPU Replacement: passo 10, imagem 1 %32
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
  11. Compaq Presario CQ62-215dx CPU Replacement: passo 11, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the three 2mm screws that connect the fan to the CPU.
  12. Compaq Presario CQ62-215dx CPU Replacement: passo 12, imagem 1 %32
    • Remove the fan from the motherboard.
    • When reassembling, you will need to solder the fan back on to the CPU.
  13. Compaq Presario CQ62-215dx CPU Replacement: passo 13, imagem 1 %32
    • Use the metal spudger to twist the lock tab on the component.
  14. Compaq Presario CQ62-215dx CPU Replacement: passo 14, imagem 1 %32
    • Remove current CPU and replace with new component.
Conclusão
Breana Thibodeaux
Membro desde: 03/24/19
760 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 1,313
