Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This is a motherboard replacement guide for the Compaq Presario CQ62. The following guide gives step by step instructions on how to remove and replace your motherboard. The mother board is a vital piece of technology in this device that allows the CPU, RAM, and a sum of other hardware components to communicate with each other.
O que você precisa
Turn the computer over as shown in the image.
Remove the two M2.5x5 screws that secure the cover of the hard drive.
To remove the keyboard, use the spudger to release the snaps between the casing and the keyboard top. Remove the snaps all the way around the device except around the LDC area.
Using a spudger, firmly press the keyboard from the function keys downward towards the bottom of the keyboard to remove the board.
To reassemble your device, follow these instructions in reverse order. To dissasemble the logic board see the other ifixit guide for this laptop.
5 outras pessoas executaram este guia.
