Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This is a motherboard replacement guide for the Compaq Presario CQ62. This guide gives step by step instructions on how to remove and replace your motherboard.
O que você precisa
When pressing down on the keyboard the force must overcome the adhesive.
When lifting out keyboard be mindfull on the keyboard flex, that need to be disconnected when keyboard is loose.
remove the flex'es by opening the connectors and remove them (5 in total).
Remove 3 screws (marked Red)
Finally the top cover can be removed with a spudger.
To reassemble your device, follow these instructions in reverse order. To dissasemble the logic board see the other ifixit guide for this laptop.
5 outras pessoas executaram este guia.
