Ir para o conteúdo principal
Compaq Presario CQ60-211DX Solid State Drive Replacement
O que você precisa
  1. Compaq Presario CQ60-211DX Solid State Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop off and disconnect all sources of power.
    • Set the laptop on a flat surface with the bottom side facing up.
  2. Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 2, imagem 1 %32 Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 2, imagem 2 %32 Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 2, imagem 3 %32
    • Slide the battery release tab.
    • This will eject the battery.
    • Carefully remove the battery and set it aside.
  3. Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): passo 3, imagem 1 %32 Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): passo 3, imagem 2 %32
    • Use a PH1 screwdriver to unscrew the 2 screws that secure the hard drive cover.
    • Remove the cover.
  4. Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 4, imagem 1 %32 Compaq Presario CQ60-211DX Solid State Drive Replacement: passo 4, imagem 2 %32
    • Unscrew the next three screws holding the hard drive in place.
    • Pull the black ribbon and slide the hard drive out of place.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 1,032
