Ir para o conteúdo principal
Compaq Presario CQ60-211DX RAM (Random Access Memory) Replacement
O que você precisa
  1. Compaq Presario CQ60-211DX RAM (Random Access Memory)  Replacement, RAM (Random Access Memory): passo 1, imagem 1 %32
    • Power off the CQ60 and unplug all cables connected to it.
  2. Compaq Presario CQ60-211DX RAM (Random Access Memory)  Replacement: passo 2, imagem 1 %32
    • Using a standard #2 Phillips-head screwdriver, remove the back compartment of the CQ60 to access the motherboard.
  3. Compaq Presario CQ60-211DX RAM (Random Access Memory)  Replacement: passo 3, imagem 1 %32
    • Use your fingers to push the retention clips away from the RAM sticks, and carefully pull out the old RAM.
  4. Compaq Presario CQ60-211DX RAM (Random Access Memory)  Replacement: passo 4, imagem 1 %32
    • Carefully insert the new RAM, and ensure that it is placed in the correct slots.
Conclusão
Garrett Carter
Membro desde: 09/21/18
471 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 733
