Ir para o conteúdo principal
Compaq Presario CQ60-211DX Display Assembly Replacement
O que você precisa
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 2, imagem 1 %32 Compaq Presario CQ60-211DX Display Assembly Replacement: passo 2, imagem 2 %32
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 3, imagem 1 %32 Compaq Presario CQ60-211DX Display Assembly Replacement: passo 3, imagem 2 %32
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 4, imagem 1 %32
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 5, imagem 1 %32
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 6, imagem 1 %32
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: passo 7, imagem 1 %32
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
Conclusão
Garrett Carter
Membro desde: 09/21/18
471 Reputação
Autoria de 4 guias
2 comentários
My laptop model Compaq predario cq61 h
Rashid 007 - Responder
Computer on but display light of computer is running
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 27
Duração total: 1,105
