Ir para o conteúdo principal
Compaq Presario CQ60 Motherboard Replacement
O que você precisa
  1. Compaq Presario CQ60 Motherboard Replacement, Slide battery latch: passo 1, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Slide battery latch: passo 1, imagem 2 %32
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Compaq Presario CQ60 Motherboard Replacement: passo 2, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 2, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement: passo 2, imagem 3 %32
    • Lift and remove battery
  3. Compaq Presario CQ60 Motherboard Replacement, Remove hard drive cover: passo 3, imagem 1 %32
    • Loosen 2 phillips screws
    • Lift and remove cover
  4. Compaq Presario CQ60 Motherboard Replacement, Remove drive caddy: passo 4, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Remove drive caddy: passo 4, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement, Remove drive caddy: passo 4, imagem 3 %32
    • Remove 3 M2.5x4mm screws
    • Slide caddy forwards
    • Lift tab to remove caddy
  5. Compaq Presario CQ60 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove 4 phillips screws to remove drive from caddy
  6. Compaq Presario CQ60 Motherboard Replacement, Unscrew keyboard: passo 6, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Unscrew keyboard: passo 6, imagem 2 %32
    • Remove 3x M2.5x4mm
  7. Compaq Presario CQ60 Motherboard Replacement, Lift keyboard: passo 7, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Lift keyboard: passo 7, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement, Lift keyboard: passo 7, imagem 3 %32
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  8. Compaq Presario CQ60 Motherboard Replacement, Detach ribbon cable: passo 8, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Detach ribbon cable: passo 8, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement, Detach ribbon cable: passo 8, imagem 3 %32
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
  9. Compaq Presario CQ60 Motherboard Replacement, Remove screws: passo 9, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Remove screws: passo 9, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement, Remove screws: passo 9, imagem 3 %32
    • Remove 2x Phillips M2.5x8mm screws from under the display
    • Remove 4x Phillips M2x2.8mm screws from the battery compartment
  10. Compaq Presario CQ60 Motherboard Replacement, Disconnect ribbon cable: passo 10, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Disconnect ribbon cable: passo 10, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement, Disconnect ribbon cable: passo 10, imagem 3 %32
    • Turn over the laptop
    • Use a spudger to lift the ribbon cable hinged clip
    • Pull the ribbon cable out of the connector
  11. Compaq Presario CQ60 Motherboard Replacement: passo 11, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 11, imagem 2 %32
    • Lifting the bezel by the screen
    • Slide the bezel back towards the screen to release it from the clips
  12. Compaq Presario CQ60 Motherboard Replacement, Remove bezel: passo 12, imagem 1 %32
    • Fully remove bezel
  13. Compaq Presario CQ60 Motherboard Replacement, Remove screws: passo 13, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Remove screws: passo 13, imagem 2 %32
    • Remove 4x #1 Phillips M2.5x8mm screws from the bottom case
    • Remove 2x #0 Phillips M2x4mm screws from hard drive bay
  14. Compaq Presario CQ60 Motherboard Replacement, Disconnect mouse ribbon cable: passo 14, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Disconnect mouse ribbon cable: passo 14, imagem 2 %32
    • Using a spudger lift the mouse ribbon cabe latch
    • Do not remove yet
  15. Compaq Presario CQ60 Motherboard Replacement: passo 15, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 15, imagem 2 %32
    • Remove 4x #1 Phillips M2x5mm
    • Remove 1x #0 Phillips M2x2.6
  16. Compaq Presario CQ60 Motherboard Replacement: passo 16, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 16, imagem 2 %32
    • Starting at the edge by the screen, use a spudger to unclip the top case
    • Work around both sides and finish with the touchpad
  17. Compaq Presario CQ60 Motherboard Replacement: passo 17, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 17, imagem 2 %32
    • Lift top base off of laptop, being careful to disconnect the touchpad ribbon cable
  18. Compaq Presario CQ60 Motherboard Replacement, Motherboard: passo 18, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement, Motherboard: passo 18, imagem 2 %32
    • Disconnect CMOS battery backup connector from bottom of laptop
  19. Compaq Presario CQ60 Motherboard Replacement: passo 19, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 19, imagem 2 %32
    • Disconnect speaker connector. This connector is easy to break, there are 2 tabs on the bottom that need to be lifted slightly to remove. Use a spudger carefully under the connector to lift slightly and pull gently on the wires all together to remove.
    • Disconnect the USB connector
  20. Compaq Presario CQ60 Motherboard Replacement: passo 20, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 20, imagem 2 %32
    • Remove 2x #1 Phillips M2.5x4.5mm screws holding the optical drive connector
    • Remove the modem port connector
  21. Compaq Presario CQ60 Motherboard Replacement: passo 21, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 21, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement: passo 21, imagem 3 %32
    • Lift audio/status light connector tab using a spudger and remove ribbon cable
  22. Compaq Presario CQ60 Motherboard Replacement: passo 22, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 22, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement: passo 22, imagem 3 %32
    • Remove 1x #0 Phillips M2x2.8mm screw from left speaker
    • Lift speaker out and place out of the way of the motherboard
  23. Compaq Presario CQ60 Motherboard Replacement: passo 23, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 23, imagem 2 %32
    • Remove 4x #1 Phillips M2.5x4mm screws
  24. Compaq Presario CQ60 Motherboard Replacement: passo 24, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 24, imagem 2 %32 Compaq Presario CQ60 Motherboard Replacement: passo 24, imagem 3 %32
    • Lift motherboard from right hand side and slide towards right
    • Be careful of power connector releasing from case
  25. Compaq Presario CQ60 Motherboard Replacement: passo 25, imagem 1 %32 Compaq Presario CQ60 Motherboard Replacement: passo 25, imagem 2 %32
    • Motherboard (with RAM) is removed
Conclusão
Uma outra pessoa concluiu este guia.
Mike B
Membro desde: 11/07/13
1.018 Reputação
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 1,056
