Ir para o conteúdo principal
Compaq Mini 110 Hard Drive Replacement
O que você precisa
  1. Compaq Mini 110 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    Pergunte ao FixBot
  2. Compaq Mini 110 Hard Drive Replacement: passo 2, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 2, imagem 2 %32 Compaq Mini 110 Hard Drive Replacement: passo 2, imagem 3 %32
    • Push both tabs inward simultaneously and slide the battery out.
    Pergunte ao FixBot
  3. Compaq Mini 110 Hard Drive Replacement, RAM: passo 3, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement, RAM: passo 3, imagem 2 %32
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    Pergunte ao FixBot
  4. Compaq Mini 110 Hard Drive Replacement: passo 4, imagem 1 %32
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    Pergunte ao FixBot
  5. Compaq Mini 110 Hard Drive Replacement, Keyboard: passo 5, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement, Keyboard: passo 5, imagem 2 %32
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    Pergunte ao FixBot
  6. Compaq Mini 110 Hard Drive Replacement: passo 6, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 6, imagem 2 %32
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    Pergunte ao FixBot
  7. Compaq Mini 110 Hard Drive Replacement: passo 7, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 7, imagem 2 %32
    • Unscrew the screw for the bottom case located in the RAM compartment.
    Pergunte ao FixBot
  8. Compaq Mini 110 Hard Drive Replacement: passo 8, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 8, imagem 2 %32
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    Pergunte ao FixBot
  9. Compaq Mini 110 Hard Drive Replacement, Hard Drive: passo 9, imagem 1 %32
    • Remove the three screws holding the panel in place.
    Pergunte ao FixBot
  10. Compaq Mini 110 Hard Drive Replacement: passo 10, imagem 1 %32 Compaq Mini 110 Hard Drive Replacement: passo 10, imagem 2 %32
    • Pull up on the tab to remove the hard drive.
    Pergunte ao FixBot
Conclusão
16 outras pessoas executaram este guia.
alea
Membro desde: 10/06/10
1.429 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 22-2, Maness Fall 2010 Membro de Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Membros
Autoria de 20 guias
2Comentários do guia
still cannot remove back of my compacq mini. i have taken all screws out as told but back refuses to part.
madudman - Responder Compartilhar
still cannot remove back of my compact after removing all screws. are ther any more hidden clips ? mike
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 101
Ao todo: 39,970
