Ir para o conteúdo principal
Compaq Evo N1000v Top Cover Replacement
O que você precisa
  1. Compaq Evo N1000v Top Cover Replacement, LED Cover: passo 1, imagem 1 %32
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Top Cover Replacement: passo 2, imagem 1 %32
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Top Cover Replacement: passo 3, imagem 1 %32
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Top Cover Replacement: passo 4, imagem 1 %32
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Top Cover Replacement: passo 5, imagem 1 %32
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Top Cover Replacement: passo 6, imagem 1 %32
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Top Cover Replacement: passo 7, imagem 1 %32
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Top Cover Replacement: passo 8, imagem 1 %32 Compaq Evo N1000v Top Cover Replacement: passo 8, imagem 2 %32
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Top Cover Replacement, Keyboard: passo 9, imagem 1 %32
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Top Cover Replacement: passo 10, imagem 1 %32
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Top Cover Replacement: passo 11, imagem 1 %32
    • Remove the keyboard.
  12. Compaq Evo N1000v Top Cover Replacement, Heat Sink: passo 12, imagem 1 %32
    • Disconnect the cable connecting the fan to the system board.
  13. Compaq Evo N1000v Top Cover Replacement: passo 13, imagem 1 %32
    • Remove the four screws from the heat sink.
  14. Compaq Evo N1000v Top Cover Replacement: passo 14, imagem 1 %32
    • Pull the the heat sink up and out of the computer.
  15. Compaq Evo N1000v Top Cover Replacement, Palm Rest: passo 15, imagem 1 %32
    • Close the laptop and flip it so the rear panel is facing up.
  16. Compaq Evo N1000v Top Cover Replacement: passo 16, imagem 1 %32
    • Using the TR8 Torx screwdriver, remove the six screws from the back case.
  17. Compaq Evo N1000v Top Cover Replacement: passo 17, imagem 1 %32
    • Remove the battery.
    • Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
    • Flip the laptop over again so the top is facing up.
    • Open the laptop screen and face it towards you.
  18. Compaq Evo N1000v Top Cover Replacement: passo 18, imagem 1 %32
    • Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
    • Be gentle as it is connected by some cables.
  19. Compaq Evo N1000v Top Cover Replacement: passo 20, imagem 1 %32
    • Disconnect the second ribbon cable.
  20. Compaq Evo N1000v Top Cover Replacement: passo 21, imagem 1 %32
    • Remove the palm rest.
  21. Compaq Evo N1000v Top Cover Replacement, Top Cover: passo 22, imagem 1 %32
    • Turn the laptop bottom side up.
  22. Compaq Evo N1000v Top Cover Replacement: passo 23, imagem 1 %32
    • Remove the two TM 2.5mm x 8.0mm screws that secure the top cover to the base.
  23. Compaq Evo N1000v Top Cover Replacement: passo 24, imagem 1 %32
    • Turn the base top side up with the front facing forward.
  24. Compaq Evo N1000v Top Cover Replacement: passo 25, imagem 1 %32
    • Remove the three TM 2.5 mm x 5.0 mm screws that secure the top cover to the base.
  25. Compaq Evo N1000v Top Cover Replacement: passo 26, imagem 1 %32
    • Lift the top cover straight up about one inch, then slide forward until the microphone cable is exposed.
    • Disconnect the microphone cable from the system board.
  26. Compaq Evo N1000v Top Cover Replacement: passo 27, imagem 1 %32
    • Remove the top cover from the base.
Conclusão
Alex Hernandez
Membro desde: 04/14/10
46 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 29-74, Johann Spring 2010 Membro de Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 3,065
