Ir para o conteúdo principal
How to Assemble the iMac Cardboard Service Wedge
O que você precisa
  1. How to Assemble the iMac Cardboard Service Wedge, Fold the tabs: passo 1, imagem 1 %32 How to Assemble the iMac Cardboard Service Wedge, Fold the tabs: passo 1, imagem 2 %32 How to Assemble the iMac Cardboard Service Wedge, Fold the tabs: passo 1, imagem 3 %32
    • With the blank side facing you, fold the two tabs inward at a 90-degree angle.
  2. How to Assemble the iMac Cardboard Service Wedge, Fold the outer side flaps: passo 2, imagem 1 %32 How to Assemble the iMac Cardboard Service Wedge, Fold the outer side flaps: passo 2, imagem 2 %32
    • Fold the two outer side flaps inward at a 90-degree angle.
  3. How to Assemble the iMac Cardboard Service Wedge, Fold it in half: passo 3, imagem 1 %32 How to Assemble the iMac Cardboard Service Wedge, Fold it in half: passo 3, imagem 2 %32 How to Assemble the iMac Cardboard Service Wedge, Fold it in half: passo 3, imagem 3 %32
    • Fold the two halves together, using the crease in the center as the folding point.
    • Overlap the two outer side flaps, making sure the flap with the two small tabs is on top.
  4. How to Assemble the iMac Cardboard Service Wedge, Insert the tabs into the slots: passo 4, imagem 1 %32 How to Assemble the iMac Cardboard Service Wedge, Insert the tabs into the slots: passo 4, imagem 2 %32 How to Assemble the iMac Cardboard Service Wedge, Insert the tabs into the slots: passo 4, imagem 3 %32
    • Insert the two tabs into the slots along the fold.
    • Make sure the flared edges on either side of the tabs are inserted completely into the slots so that they lock in place and don't slide out.
  5. How to Assemble the iMac Cardboard Service Wedge, Place it under your iMac: passo 5, imagem 1 %32 How to Assemble the iMac Cardboard Service Wedge, Place it under your iMac: passo 5, imagem 2 %32
    • Your iMac Cardboard Service Wedge is ready to go!
    • Insert the Service Wedge under the iMac's display to hold it in place while you perform repairs on your iMac.
Linha de Chegada
38 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
35.354 Reputação
Autoria de 82 guias
Um comentário
Nice explanation, however, the cardboard stand is available in the US and not here and so it the dual HD cable for the iMac Intel 27” (mid 2011).
No good posting a great helps tory if the parts are not sold in Australia.
Hank Doll - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 53
Últimos 30 dias: 266
Duração total: 11,175
