Ir para o conteúdo principal
How to Disconnect an iPad Battery with a Playing Card
O que você precisa
  1. How to Disconnect an iPad Battery with a Playing Card, Mark the screw slot and total width: passo 1, imagem 1 %32 How to Disconnect an iPad Battery with a Playing Card, Mark the screw slot and total width: passo 1, imagem 2 %32
    • Line up the left edge of a playing card with the left edge of the battery connector.
    • Use a pen to mark both sides of the screw hole and the end of the battery connector as shown.
  2. How to Disconnect an iPad Battery with a Playing Card, Mark the depth of the screw slot: passo 2, imagem 1 %32 How to Disconnect an iPad Battery with a Playing Card, Mark the depth of the screw slot: passo 2, imagem 2 %32
    • Line up the top edge of the card with the top edge of the screw hole.
    • Use a pen to mark the bottom edge of the battery connector.
    • These markings will aid in cutting a slot in the card to clear the screw hole.
  3. How to Disconnect an iPad Battery with a Playing Card, Cut the playing card to size: passo 3, imagem 1 %32 How to Disconnect an iPad Battery with a Playing Card, Cut the playing card to size: passo 3, imagem 2 %32
    • The length of the battery blocker is not important, but we recommend it to be about an inch, or the length from the tip of your thumb to its knuckle.
    • Use a pair of scissors to cut out the playing card battery blocker as shown.
  4. How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: passo 4, imagem 1 %32 How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: passo 4, imagem 2 %32 How to Disconnect an iPad Battery with a Playing Card, Disconnect the battery: passo 4, imagem 3 %32
    • Be extremely slow and careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Insert the battery blocker at a 35 degree angle to disconnect the battery.
    • The playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
Conclusão
8 outras pessoas executaram este guia.
Robert Boyd
Membro desde: 02/01/21
26.500 Reputação
Autoria de 94 guias
Um comentário
Thanks Robert. Great easy to create tool and excellent explanation.
Kevin Stark - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 53
Últimos 30 dias: 255
Duração total: 9,171
