Ir para o conteúdo principal
Commodore 64 VIC Chip Replacement
O que você precisa
  1. Cuidado: as etapas de 1 a 2 são provenientes de um guia marcado como em andamento.
    Commodore 64 VIC Chip Replacement, Removing screws: passo 1, imagem 1 %32 Commodore 64 VIC Chip Replacement, Removing screws: passo 1, imagem 2 %32 Commodore 64 VIC Chip Replacement, Removing screws: passo 1, imagem 3 %32
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 VIC Chip Replacement, Opening: passo 2, imagem 1 %32 Commodore 64 VIC Chip Replacement, Opening: passo 2, imagem 2 %32
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: passo 3, imagem 1 %32 Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: passo 3, imagem 2 %32
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
  4. Commodore 64 VIC Chip Replacement, Pull up the VIC plate: passo 4, imagem 1 %32 Commodore 64 VIC Chip Replacement, Pull up the VIC plate: passo 4, imagem 2 %32
    • 2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
  5. Commodore 64 VIC Chip Replacement, Removing the Chip: passo 5, imagem 1 %32 Commodore 64 VIC Chip Replacement, Removing the Chip: passo 5, imagem 2 %32
    • 3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
    • You can insert a new VIC chip by making it clip back in on the board
Conclusão
Silvanus Clarke
Membro desde: 09/26/14
656 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 13-6, Staggers Fall 2014 Membro de USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
Membros da 4
Autoria de 15 guias
Um comentário
It's awesome to see that people care enough about these machines to make repair guides about them! Great job!
[deleted] - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 31
Duração total: 4,656
