Ir para o conteúdo principal
Commodore 64 Central Processing Unit (CPU) Replacement
O que você precisa
  1. Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: passo 1, imagem 1 %32 Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: passo 1, imagem 2 %32 Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: passo 1, imagem 3 %32
    • 1. Remove three 6.75mm ph2 screw heads from the casing
    Pergunte ao FixBot
    Comentar
  2. Commodore 64 Central Processing Unit (CPU) Replacement, Opening: passo 2, imagem 1 %32 Commodore 64 Central Processing Unit (CPU) Replacement, Opening: passo 2, imagem 2 %32
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
    Pergunte ao FixBot
    Comentar
  3. Commodore 64 Central Processing Unit (CPU) Replacement, Detach Keyboard from the motherboard: passo 3, imagem 1 %32 Commodore 64 Central Processing Unit (CPU) Replacement, Detach Keyboard from the motherboard: passo 3, imagem 2 %32
    • 1. Detach the multi-colored wire bundles connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Commodore 64 Central Processing Unit (CPU) Replacement, Locate the CPU: passo 4, imagem 1 %32
    • Locate the CPU chip which is labeled 'MOS 6510 3782'
    Pergunte ao FixBot
    Comentar
  5. Commodore 64 Central Processing Unit (CPU) Replacement, Removing the CPU chip: passo 5, imagem 1 %32 Commodore 64 Central Processing Unit (CPU) Replacement, Removing the CPU chip: passo 5, imagem 2 %32
    • 3. Loosen the CPU chip with a Phillips screwdriver. Then use your hand to pry up the CPU chip from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 13-6, Staggers Fall 2014 Membro de USF Tampa, Team 13-6, Staggers Fall 2014
USFT-STAGGERS-F14S13G6
4 Membros
Autoria de 15 guias
1Comentário do guia
there are two problems
1. Use an spudger for lifting the C.P.U instead of an screw driver bit to help alleviate concerns of bending the pins,
2. There is an step missing which involves cutting the tape seen here.
- Jordan .F
Jordan Fryman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 29
Ao todo: 3,360
