Ir para o conteúdo principal
Commercial Electric MMA-8302R Multimeter Fuse Replacement
O que você precisa
  1. Commercial Electric MMA-8302R Multimeter Fuse Replacement, Turn off multimeter and unplug the two leads.: passo 1, imagem 1 %32 Commercial Electric MMA-8302R Multimeter Fuse Replacement, Turn off multimeter and unplug the two leads.: passo 1, imagem 2 %32
    • Turn the dial until the little green mark is set on the "OFF" option. Next disconnect the two testing leads by simply pulling them away from the body. Set these aside for later.
  2. Commercial Electric MMA-8302R Multimeter Fuse Replacement, Unscrew the four phillips screws that hold the back panel: passo 2, imagem 1 %32 Commercial Electric MMA-8302R Multimeter Fuse Replacement, Unscrew the four phillips screws that hold the back panel: passo 2, imagem 2 %32 Commercial Electric MMA-8302R Multimeter Fuse Replacement, Unscrew the four phillips screws that hold the back panel: passo 2, imagem 3 %32
    • Unscrew the four Phillips screws that hold the back panel and carefully open it from either side and lay it besides the main body, try not to break the top led cable.
    • Disconnect the top led cable from the PCB and move everything aside.
  3. Commercial Electric MMA-8302R Multimeter Fuse Replacement, Swap out the fuses: passo 3, imagem 1 %32
    • Swap the blown fuses out for new ones and you're done!
Conclusão
4 outras pessoas executaram este guia.
DeZom
Membro desde: 02/12/22
955 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 54
Ao todo: 2,216
