Ir para o conteúdo principal
Comment forcer le redémarrage de l'iPhone Xs
O que você precisa
  1. Comment forcer le redémarrage de l'iPhone Xs, Comment forcer le redémarrage de l'iPhone Xs: passo 1, imagem 1 %32
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone Xs: passo 2, imagem 1 %32
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    Thank you so much for such a simplified step by step guide. I was pulling my hair out for 5 hours since the other websites weren’t specific enough on how long to hold down the Volume up and down button.
    Jayman - Responder
Linha de Chegada
60 outras pessoas executaram este guia.
5 comentários
this method of shutdown would not work for me. And I can’t open up setting to go under general to shutdown either
Peggy Biggs - Responder
Intead use 3utool in computer and restart. I used to do it
raju kb - Responder
Worked as it said it would. Thank you
jillfarrell5707 - Responder
pas moyen de redémarrer avec cette méthode… le mac ne reconnait pas l’Iphone XS
clement.dominiquepascal - Responder
i tryed one way fro force start my i phone xs
press up volume botton and relerese and down volume bottle and quicj release and then hold right side button hold longer time but not work out
suhad patel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 26
Últimos 7 dias: 196
Últimos 30 dias: 771
Duração total: 209,476
