Ir para o conteúdo principal
  1. Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
Linha de Chegada
95 outras pessoas concluíram este guia.
Equipe
iGH Membro de iGH
Business
1 Membro
73 Guias de autoria
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - Responder
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - Responder
good share. thanks.
MelissaR - Responder
What is the other way?
sa sas - Responder
will it delete all data from my iPhone?
_TR0xuu_ - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 60
Últimos 7 dias: 495
Últimos 30 dias: 2,137
Duração total: 259,272
