Ir para o conteúdo principal
Comment forcer le redémarrage de l'iPhone 8 Plus
O que você precisa
  1. Comment forcer le redémarrage de l'iPhone 8 Plus, Comment forcer le redémarrage de l'iPhone 8 Plus: passo 1, imagem 1 %32
    • appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
    The picture makes it look like you need to start this process with the phone turned on already, but I think you need to start with it powered off - that’s the only way that long-pressing the power button in Step 2 causes the Apple logo to appear.
    Owen Edwards - Responder
    For an iPhone 8, step #3 is to press and hold the right-side button. Continue holding the button down until the apple logo appears, then release.
    sjf - Responder
    what if the apple logo appears but nothing else happens. it just keeps showing the logo.
    LeRoyal - Responder
  2. Comment forcer le redémarrage de l'iPhone 8 Plus: passo 2, imagem 1 %32
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    How can i have apple id and password to fix my phone
    Mhreteab Adresom - Responder
Linha de Chegada
65 outras pessoas executaram este guia.
2 comentários
What if my side power button doesn’t work?
Alex Busnelli - Responder
Are there any preconditions? Like should the iPhone be ON before step 1?
Are there any side effects? Like resetting momory, settings, etc?
Eric Bolinger - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 141
Últimos 30 dias: 602
Duração total: 39,853
