Ir para o conteúdo principal
Comment forcer le redémarrage de l'iPhone 8
O que você precisa
  1. Comment forcer le redémarrage de l'iPhone 8, Comment forcer le redémarrage de l'iPhone 8: passo 1, imagem 1 %32
    • appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone 8: passo 2, imagem 1 %32
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
Linha de Chegada
37 outras pessoas executaram este guia.
9 comentários
Very helpfully, thanks!
user7 - Responder
helpfully, thanks!
pat trixia - Responder
All that happens for me is getting the slide to power off..never a reset. About to throw the phone.
Cheri Hogan - Responder
Same as above. Slide to power off and not able to slide. It is frustrating.
nick_nic112 - Responder
I suggest you learn to read. hold power until apple sign appears. you need to keep holding it. not sliding it to switch off.
Gurin Jeimuzu -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 22
Últimos 7 dias: 252
Últimos 30 dias: 793
Duração total: 65,923
