Ir para o conteúdo principal
Comfort Zone CZ6C Fan Blades Replacement
O que você precisa
  1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: passo 1, imagem 1 %32 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: passo 1, imagem 2 %32 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: passo 1, imagem 3 %32
    • The metal cage is kept in place by three plastic tabs on the plastic body. Focus your pulling around these tabs to make the job easier.
    • In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
    • Now work your way around the edge of the fan cage and pull it away from the plastic body.
  2. Comfort Zone CZ6C Fan Blades Replacement: passo 2, imagem 1 %32 Comfort Zone CZ6C Fan Blades Replacement: passo 2, imagem 2 %32
    • To remove the fan blade, reach behind it and slowly pull it towards you.
    • If the fan blade axle has any hair or dirt, then clean it with a cloth to avoid further fan blade blockage.
    • If you are having difficulty removing the fan blade, then generously apply WD-40 to the fan blade axle.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 17-5, Forte Spring 2015 Membro de Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
Membros da 4
Autoria de 5 guias
2 comentários
Where does one buy the replacement blades?
Frank Gould - Responder
where does one buy the replacement blades??
Luis Marrero - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 33
Duração total: 5,845
