Ir para o conteúdo principal
ComNet Ericsson Panther 600P Speaker Replacement
O que você precisa
  1. ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: passo 1, imagem 1 %32 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: passo 1, imagem 2 %32 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: passo 1, imagem 3 %32
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Speaker Replacement, Antenna: passo 2, imagem 1 %32
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Speaker Replacement, Dials: passo 3, imagem 1 %32
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: passo 4, imagem 1 %32 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: passo 4, imagem 2 %32 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: passo 4, imagem 3 %32
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Speaker Replacement, Speaker: passo 5, imagem 1 %32 ComNet Ericsson Panther 600P Speaker Replacement, Speaker: passo 5, imagem 2 %32
    • Locate the device's speaker inside the front panel of the exterior case.
    • Locate the display and speaker stabilizer.
    • Lift the stabilizer up from the bottom and pull the stabilizer out of case.
  6. ComNet Ericsson Panther 600P Speaker Replacement: passo 6, imagem 1 %32 ComNet Ericsson Panther 600P Speaker Replacement: passo 6, imagem 2 %32 ComNet Ericsson Panther 600P Speaker Replacement: passo 6, imagem 3 %32
    • Locate the two 3.75mm screws holding the speaker to the exterior case.
    • Using a T15 Torx screwdriver, unscrew the 3.75mm screws.
  7. ComNet Ericsson Panther 600P Speaker Replacement: passo 7, imagem 1 %32 ComNet Ericsson Panther 600P Speaker Replacement: passo 7, imagem 2 %32
    • Lift up on the bottom of the speaker to detach the speaker.
    • Pull the speaker out of the case.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 184
