Ir para o conteúdo principal
ComNet Ericsson Panther 600P Motherboard Replacement
O que você precisa
  1. ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: passo 1, imagem 1 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: passo 1, imagem 2 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: passo 1, imagem 3 %32
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Motherboard Replacement, Antenna: passo 2, imagem 1 %32
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Motherboard Replacement, Dials: passo 3, imagem 1 %32
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: passo 4, imagem 1 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: passo 4, imagem 2 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: passo 4, imagem 3 %32
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: passo 5, imagem 1 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: passo 5, imagem 2 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: passo 5, imagem 3 %32
    • Using the plastic opening tool, pry the case apart.
  6. ComNet Ericsson Panther 600P Motherboard Replacement, Ribbon: passo 6, imagem 1 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Ribbon: passo 6, imagem 2 %32
    • The keypad chip is attached to the motherboard by a ribbon.
    • Pull ribbon with tweezers to detach from back panel.
  7. ComNet Ericsson Panther 600P Motherboard Replacement, Screen: passo 7, imagem 1 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Screen: passo 7, imagem 2 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Screen: passo 7, imagem 3 %32
    • Screen will be attached by a ribbon.
    • Pull screen up and away from motherboard to detach.
  8. ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: passo 8, imagem 1 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: passo 8, imagem 2 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: passo 8, imagem 3 %32
    • Remove the rubber O-rings from the antenna jack, volume switch, and channel switch.
    • Once the rubber O-rings have been removed, use small needle nose pliers to unscrew the nuts on the antenna jack, volume switch, and channel switch.
    • There are washers underneath the nuts on the antenna jack, volume switch, and channel switch. Set these washers aside.
  9. ComNet Ericsson Panther 600P Motherboard Replacement: passo 9, imagem 1 %32
    • Using a T15 Torx screwdriver, unscrew the 3.8mm screw from the case.
  10. ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: passo 10, imagem 1 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: passo 10, imagem 2 %32 ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: passo 10, imagem 3 %32
    • Using any convenient hand-placement, pull the motherboard away from the case.
    • The antenna jack, volume dial, and channel dial are attached to the motherboard. Be sure to pull the motherboard downward so they clear their respective slots in the case.
    • Lift the motherboard completely free of the case.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 322
