Ir para o conteúdo principal
ComNet Ericsson Panther 600P Buttons Replacement
O que você precisa
  1. ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: passo 1, imagem 1 %32 ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: passo 1, imagem 2 %32 ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: passo 1, imagem 3 %32
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Buttons Replacement, Antenna: passo 2, imagem 1 %32
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Buttons Replacement, Dials: passo 3, imagem 1 %32
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: passo 4, imagem 1 %32 ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: passo 4, imagem 2 %32 ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: passo 4, imagem 3 %32
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Buttons Replacement, Remove Buttons: passo 5, imagem 1 %32 ComNet Ericsson Panther 600P Buttons Replacement, Remove Buttons: passo 5, imagem 2 %32
    • Grip the corner of the button pad and gently peal it away from the faceplate.
    • Clean off any sticky residue and/or replace the buttons.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 205
