Ir para o conteúdo principal
Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement
O que você precisa
  1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: passo 1, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: passo 1, imagem 2 %32
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 2, imagem 1 %32
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 3, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 3, imagem 2 %32
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 4, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 4, imagem 2 %32 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 4, imagem 3 %32
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: passo 5, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: passo 5, imagem 2 %32
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 6, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 6, imagem 2 %32
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 7, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 7, imagem 2 %32 Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: passo 7, imagem 3 %32
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
Conclusão
Mathew Merrick
Membro desde: 09/17/18
169 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 558
