Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Is your switch unable to move due to a foreign liquid? Does the switch feel like its seated improperly? Check out this guide on removing and replacing the switch.
  1. Carefully turn the lantern upside down. Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Carefully pull the bottom of the lantern to remove the base from the device.
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Gently pull the battery out of the slot and away from the base. The battery may be held into place by adhesive strips.
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  5. Carefully detach  the negative wire from the battery terminal first. Next, detach the positive wire from the battery terminal. Next, detach the positive wire from the battery terminal.
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  6. Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern. Remove the plastic barrier.
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  7. Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing. Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  8. Gently grab the main board by the exposed PCB. Pull the main board straight out of the housing. Pull the main board straight out of the housing.
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
  9. Remove the switch by pushing down on the ends while simultaneously pulling it out of the slot. When removing the switch, make sure to depress the inner clips when removing from the device. Be careful, do not force the switch from the base of the lantern.
    • Remove the switch by pushing down on the ends while simultaneously pulling it out of the slot.
    • When removing the switch, make sure to depress the inner clips when removing from the device. Be careful, do not force the switch from the base of the lantern.
Conclusão
Mathew Merrick
Membro desde: 17/09/2018
169 Reputação
2 Guias de autoria
Equipe
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 124
