Ir para o conteúdo principal
Coleman Rechargeable Fluorescent Twin Tube Battery Replacement
O que você precisa
  1. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: passo 1, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: passo 1, imagem 2 %32
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 2, imagem 1 %32
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 3, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 3, imagem 2 %32
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 4, imagem 1 %32 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 4, imagem 2 %32 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: passo 4, imagem 3 %32
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
Conclusão
Sean
Membro desde: 09/17/18
265 Reputação
Autoria de 2 guias
Equipe
Um comentário
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
BilMcKelvy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 93
Duração total: 4,889
