Ir para o conteúdo principal
Coby Kyros MID9742 Screen Replacement
O que você precisa
  1. Coby Kyros MID9742 Screen Replacement, Outer Casing: passo 1, imagem 1 %32
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Coby Kyros MID9742 Screen Replacement: passo 2, imagem 1 %32
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. Coby Kyros MID9742 Screen Replacement: passo 3, imagem 1 %32
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  4. Coby Kyros MID9742 Screen Replacement, Screen: passo 4, imagem 1 %32
    • Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
  5. Coby Kyros MID9742 Screen Replacement: passo 5, imagem 1 %32
    • Before removing the screen from the cover, dissconnect the large gold ribbon cable by gently sliding the black tab out until it clicks.
    • Gently pull the ribbon cable from the port.
  6. Coby Kyros MID9742 Screen Replacement: passo 6, imagem 1 %32
    • Remove the screen from the device.
Conclusão
Ian Swett
Membro desde: 03/11/15
597 Reputação
Autoria de 5 guias
Equipe
Colorado Springs, Team 5-3, Panko Spring 2015 Membro de Colorado Springs, Team 5-3, Panko Spring 2015
UCCS-PANKO-S15S5G3
Membros da 3
Autoria de 12 guias
3 comentários
Is the flex cable detachable from the LCD
maynell Rodrigues - Responder
Do u have the display flex cable
how much does it cost for screen
jnapps mu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,068
