Introdução
This process is easy, but will require some soldering.
O que você precisa
Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
Use the PH00 screwdriver to remove the six 0.25 cm screws circled in the image.
Uma outra pessoa concluiu este guia.
