Ir para o conteúdo principal
Coby Kyros MID9042 Camera Replacement
O que você precisa
  1. Coby Kyros MID9042 Camera Replacement, Camera: passo 1, imagem 1 %32 Coby Kyros MID9042 Camera Replacement, Camera: passo 1, imagem 2 %32 Coby Kyros MID9042 Camera Replacement, Camera: passo 1, imagem 3 %32
    • Before removing anything from the tablet, make sure to power off the device.
    • After powering off device, remove the anti-slip pads from all 4 corners on the back of the device.
    • Once slip pads are removed, proceed to unscrewing the four 3.2 mm Phillips #0 screws from the back cover.
  2. Coby Kyros MID9042 Camera Replacement: passo 2, imagem 1 %32 Coby Kyros MID9042 Camera Replacement: passo 2, imagem 2 %32 Coby Kyros MID9042 Camera Replacement: passo 2, imagem 3 %32
    • When removing the back cover, be careful not to break the inner plastic tabs.
    • Use the blue plastic opening tool to wedge the back cover apart from the front.
    • Once the edges are wedged apart, use hands to lift up the back of the tablet.
  3. Coby Kyros MID9042 Camera Replacement: passo 3, imagem 1 %32 Coby Kyros MID9042 Camera Replacement: passo 3, imagem 2 %32 Coby Kyros MID9042 Camera Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the gold flap and use tweezers to lift the flap up.
    • Use a second pair of tweezers to pull the gold tab connected to the camera out of the circuit board.
    • Once the tab is removed from the circuit board, pull the camera out of the tablet.
    • Caution! Be sure to avoid pulling the gold flap off the the circuit board.
Conclusão
Samantha Rollings
Membro desde: 03/30/15
349 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 2-6, Shastany Spring 2015 Membro de UMass Dartmouth, Team 2-6, Shastany Spring 2015
UMASSD-SHASTANY-S15S2G6
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 300
