Ir para o conteúdo principal
Coby Kyros MID9042 Battery Replacement
O que você precisa
  1. Coby Kyros MID9042 Battery Replacement, Battery: passo 1, imagem 1 %32 Coby Kyros MID9042 Battery Replacement, Battery: passo 1, imagem 2 %32 Coby Kyros MID9042 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Before taking the tablet apart, power off the device.
    • Remove anti-slip pads from all four corners of the back of the device with a nylon spudger.
    • Remove the four 1/8" screws using a Phillips #0 screwdriver.
  2. Coby Kyros MID9042 Battery Replacement: passo 2, imagem 1 %32 Coby Kyros MID9042 Battery Replacement: passo 2, imagem 2 %32 Coby Kyros MID9042 Battery Replacement: passo 2, imagem 3 %32
    • Potential for device damage: Be careful not to break the inner plastic tabs while pulling the back cover off.
    • Use an opening tool to wedge the back cover apart from the front.
    • Once the edges are wedged apart, use your hands to remove the back of the tablet.
  3. Coby Kyros MID9042 Battery Replacement: passo 3, imagem 1 %32 Coby Kyros MID9042 Battery Replacement: passo 3, imagem 2 %32 Coby Kyros MID9042 Battery Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • With the soldering iron, desolder the red and black battery wires from the circuit board.
    • Use the tweezers to connect the red wire to the positive and the black wire to the negative.
Conclusão
Samantha Rollings
Membro desde: 03/30/15
349 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 2-6, Shastany Spring 2015 Membro de UMass Dartmouth, Team 2-6, Shastany Spring 2015
UMASSD-SHASTANY-S15S2G6
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,071
