Ir para o conteúdo principal
Coby Kyros MID7125 Speaker Replacement
O que você precisa
  1. Coby Kyros MID7125 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Use opening too to make small opening in the side of the device.
    • Use plastic opening tool to pry the rest of the panel off.
  2. Coby Kyros MID7125 Speaker Replacement: passo 2, imagem 1 %32
    • Once inside the device, locate the speakers on the inside of the back panel.
  3. Coby Kyros MID7125 Speaker Replacement: passo 3, imagem 1 %32
    • Use spudger to pry one speaker up off of the back panel.
  4. Coby Kyros MID7125 Speaker Replacement: passo 4, imagem 1 %32
    • Desolder the soldering points that connect the speaker to the motherboard.
  5. Coby Kyros MID7125 Speaker Replacement: passo 5, imagem 1 %32
    • Use a soldering iron to solder the wires of the new speaker to the motherboard.
    • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
  6. Coby Kyros MID7125 Speaker Replacement: passo 6, imagem 1 %32
    • Click the new speaker into the spot where you removed the old speaker.
    • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
Conclusão
Nicole Connelly
Membro desde: 10/20/16
1 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 5-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 137
