Ir para o conteúdo principal
Coby Kyros MID7125 Battery Replacement
O que você precisa
  1. Coby Kyros MID7125 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby Kyros MID7125 Battery Replacement: passo 2, imagem 1 %32
    • Locate battery. The battery is the silver coated square shaped device on the top of the motherboard.
  3. Coby Kyros MID7125 Battery Replacement: passo 3, imagem 1 %32
    • There is a small ribbon cable located under the battery. running from the volume buttons underneath the batter to main logic board.
  4. Coby Kyros MID7125 Battery Replacement: passo 4, imagem 1 %32
    • Knowing the location the ribbon cable, use plastic spudger to pry off battery.
  5. Coby Kyros MID7125 Battery Replacement: passo 5, imagem 1 %32
    • After the battery is free from the logic board, find the positive and negative wires that connect the battery to the motherboard
  6. Coby Kyros MID7125 Battery Replacement: passo 6, imagem 1 %32
    • Using a soldering gun, heat up both soldering points.
    • Remove wires from logic board
    • Clean up soldering joints with a desoldering sucker
    • Solder the new battery wires to the same soldering points as the old battery
    • Reverse steps 1-5 to put device back together
Conclusão
Uma outra pessoa concluiu este guia.
Ryan
Membro desde: 10/20/16
108 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-2, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 478
