Ir para o conteúdo principal
Coby DVD209 4-Pin Ribbon Cable Replacement
O que você precisa
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: passo 1, imagem 1 %32 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: passo 1, imagem 2 %32 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: passo 1, imagem 3 %32
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: passo 2, imagem 1 %32 Coby DVD209 4-Pin Ribbon Cable Replacement: passo 2, imagem 2 %32 Coby DVD209 4-Pin Ribbon Cable Replacement: passo 2, imagem 3 %32
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: passo 3, imagem 1 %32 Coby DVD209 4-Pin Ribbon Cable Replacement: passo 3, imagem 2 %32 Coby DVD209 4-Pin Ribbon Cable Replacement: passo 3, imagem 3 %32
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: passo 4, imagem 1 %32 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: passo 4, imagem 2 %32 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: passo 4, imagem 3 %32
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
Conclusão
Uma outra pessoa concluiu este guia.
Yufay Chow
Membro desde: 01/23/12
92 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 10-36, Amido Winter 2012 Membro de Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,007
