Ir para o conteúdo principal
Coby DVD-R11000 Outer Casing Replacement
O que você precisa
  1. Coby DVD-R11000 Outer Casing Replacement, Outer Casing: passo 1, imagem 1 %32 Coby DVD-R11000 Outer Casing Replacement, Outer Casing: passo 1, imagem 2 %32 Coby DVD-R11000 Outer Casing Replacement, Outer Casing: passo 1, imagem 3 %32
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 Outer Casing Replacement: passo 2, imagem 1 %32 Coby DVD-R11000 Outer Casing Replacement: passo 2, imagem 2 %32 Coby DVD-R11000 Outer Casing Replacement: passo 2, imagem 3 %32
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
Conclusão
Uma outra pessoa concluiu este guia.
Andrew
Membro desde: 10/22/14
501 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 149
