Ir para o conteúdo principal
Coby DVD-R11000 Fuse Replacement
O que você precisa
  1. Coby DVD-R11000 Fuse Replacement, Outer Casing: passo 1, imagem 1 %32 Coby DVD-R11000 Fuse Replacement, Outer Casing: passo 1, imagem 2 %32 Coby DVD-R11000 Fuse Replacement, Outer Casing: passo 1, imagem 3 %32
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 Fuse Replacement: passo 2, imagem 1 %32 Coby DVD-R11000 Fuse Replacement: passo 2, imagem 2 %32 Coby DVD-R11000 Fuse Replacement: passo 2, imagem 3 %32
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
  3. Coby DVD-R11000 Fuse Replacement, 3-Pin Power Cable: passo 3, imagem 1 %32 Coby DVD-R11000 Fuse Replacement, 3-Pin Power Cable: passo 3, imagem 2 %32
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
  4. Coby DVD-R11000 Fuse Replacement, Circuit Boards: passo 4, imagem 1 %32 Coby DVD-R11000 Fuse Replacement, Circuit Boards: passo 4, imagem 2 %32
    • Position the DVD player so that the side with golden circuit board, where the power cord was plugged into, is closest to you.
    • Remove the black wire with the 6-pin white adapter, which is adjacent to the other three pin adapter wires on the golden circuit board.
  5. Coby DVD-R11000 Fuse Replacement: passo 5, imagem 1 %32 Coby DVD-R11000 Fuse Replacement: passo 5, imagem 2 %32 Coby DVD-R11000 Fuse Replacement: passo 5, imagem 3 %32
    • Position the DVD player so that the back panel is facing you.
    • Remove the three wires with the white pin adapters from the golden circuit board.
  6. Coby DVD-R11000 Fuse Replacement: passo 6, imagem 1 %32 Coby DVD-R11000 Fuse Replacement: passo 6, imagem 2 %32 Coby DVD-R11000 Fuse Replacement: passo 6, imagem 3 %32
    • Remove the four half inch screws, located at each corner of the golden circuit board, using the Phillips #1 screwdriver.
    • Place the blue plastic tool opener underneath the side of the circuit board and carefully remove it from the DVD player.
  7. Coby DVD-R11000 Fuse Replacement: passo 7, imagem 1 %32 Coby DVD-R11000 Fuse Replacement: passo 7, imagem 2 %32 Coby DVD-R11000 Fuse Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Position the DVD player so that the front is facing you.
    • Using the tweezers and the blue plastic opening tool, disconnect the ribbon cables from the green circuit board where the I/O ports are attach to.
  8. Coby DVD-R11000 Fuse Replacement: passo 8, imagem 1 %32 Coby DVD-R11000 Fuse Replacement: passo 8, imagem 2 %32 Coby DVD-R11000 Fuse Replacement: passo 8, imagem 3 %32
    • Remove the three wires with the white pin adapters from the green circuit board that you just disconnected the ribbon wires from.
  9. Coby DVD-R11000 Fuse Replacement: passo 9, imagem 1 %32 Coby DVD-R11000 Fuse Replacement: passo 9, imagem 2 %32 Coby DVD-R11000 Fuse Replacement: passo 9, imagem 3 %32
    • Remove the seven 1cm screws located on the back panel of the outer casing, in between the I/O ports, with the Phillips #1 screwdriver
    • Grab the sides of the back panel and remove it from the DVD player.
  10. Coby DVD-R11000 Fuse Replacement: passo 10, imagem 1 %32 Coby DVD-R11000 Fuse Replacement: passo 10, imagem 2 %32
    • Remove the two 1cm screws that are circled in red.
  11. Coby DVD-R11000 Fuse Replacement, Fuse: passo 11, imagem 1 %32 Coby DVD-R11000 Fuse Replacement, Fuse: passo 11, imagem 2 %32
    • De-solder the electronic components that are circled in red from the golden circuit board, which is the first one you removed.
Conclusão
Andrew
Membro desde: 10/22/14
501 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 481
